RCU Forums - View Single Post - glow plug question
Old 06-06-2009 | 06:17 PM
carrellh's Avatar
carrellh
Default RE: glow plug question
According to this page http://www.rcplanet.com/Glow_Plugs_s/870.htm the MC-8 would be a terrible choice for any four stroke engine.
Mc Coy Glow Plugs Chart
MC-4C : 4-cycle plug and used in all Saito engines.
MC-55: The MC-55 is considered a hot plug and is designed to run on fuel with a low nitro content. Applications for this plug would be planes, tether cars, etc.
MC-59: Like the MC-55, the MC-59 is considered a hot plug. The difference between the 55 and 59 is that the MC-59 is designed to run on fuel with a higher nitro content (low to medium nitro content) than the MC-55. Applications: Boats, planes, helicopters, and cars.
MC-8: The MC-8 is a medium to cold plug, designed to run on fuels with a medium to high nitro content. Applications: Boats, cars, and planes.
MC-9: The McCoy MC-9 is considered a cold plug and is designed to run on fuels with a medium to high nitro content. Applications: Cars, boats, ducted fan and Giant Scale planes.
MC-14: The MC-14 is a hot plug, designed for helicopters and 4-stroke engines. This plug has a 24K gold stem.
First I would get a 'four stroke' glow plug. I like the OS-F but others probably also work well.
Next I would check the valve lash and adjust if needed.
Gray Beard mentioned making sure the fuel pump is working correctly. I do not know anything about pumps but it makes sense that it could wear out or get debris in it. You know it is at least three years old. I have no idea how long the pump diaphragm and other parts should last.
