RCU Forums - View Single Post - tire bending. how do i fix?
Old 06-06-2009 | 11:38 PM
toothman
Default tire bending. how do i fix?
i have a super trainer 60 and its great. one thing tho is when i come into land the front landing gear bends backwards. how do i fix that? do i get bigger guage wire? i do flare the plane at the end and it still bends. i have gotten MUCH bigger tires also because im landing on a ruff lawn with fairly high grass. wat would you suggest? also by putting larger tires on the front wheel alone should i put a little lead tape in the back of the plane to balance it out? i have notice segnificant drag and weight pulling the front down to the ground.
