RCU Forums - View Single Post - 4 stroke spool down???
Old 06-07-2009 | 06:52 PM
ProBroJoe's Avatar
ProBroJoe
Default RE: 4 stroke spool down???
Actually, when a four stroke behaves like that I've found that's it's a sure sign that the low-end is a just little lean. Which also explains why you can't get the idle much lower without the thing cutting out. I think you'll find if you open the low end mixture adjustment a quarter turn or so, she'll behave a little more predictably for you.
Hope this helps,
-Joe
