ORIGINAL: Metallover
Erevonut, It doesn't matter if you charge them in a series or parallel, but make sure you balance them together. You'll need a balance adapter.
Well if you clicked the link you would have seen that I have found 2 different ways to make the balance adapter and im curious which 1 most use.
Im also wondering if I can hook a 2s balancer up to each pack but still charge them as a 4s.
Lipos didnt seem that confusing until I started researching them now its more confuseing.
Edit:
Hey did you use rit dye to do your chassis?
