RCU Forums - View Single Post - Hysol VS Epoxy
Old 06-08-2009 | 01:01 PM
KC36330
Default RE: Hysol VS Epoxy
ORIGINAL: siclick33
............. I needed to remove the former completely and just gave it a hard tug and it came off in my hand. This former was glued in with hand mixed Hysol.
then whomever didn't properly install it. if the fiberglass had been sanded, wiped with alcohol and then glued you can't pull it off without damaging the fiberglass. same for two wood pcs joined with it, you'll tear wood off before you can brake the joint.
