RCU Forums - View Single Post - Help needed with 52cc Hobby King engine
Old 06-09-2009 | 07:16 AM
coralcape
Default RE: Help needed with 52cc Hobby King engine
To check the ignition, you can use an electronic timing light. Just make a TDC mark on your prop adaptor. Use a separate 12 v battery for the light, with thenegative hooked to engine ground. Good luck, red
