Okay, I decided to do it, Angel with YS63
I've installed servos and other stuff, now I have to install the motor. I will use Sebart's glow conversion kit, just like Niccolo Nassi at the video from Sebart's site. I also bought Hatori muffler, my friends said that the including muffler isn't so good. I think there is no problems to fit Hatori setup in Angel, there is quite much room under motor mount.
Servos are DS 821, throttle servo Hs 81. I will first try to fly with DS 821 original horns, but I think that I have to change them to Dubro's extra long horns to get enough control throws for Freestyle/3D.
Battery Hyperion G3 1600mAh 2S
CC 10A BEC and Power box Smart switch
AR 7000 receiver
I can tell you flight reports when it flys and post some pics.
I wanted to get YS, because I will fly both, F3A and Freestyle. In freestyle a good throttle response is needed.
Janne</p>
