RCU Forums - View Single Post - Setting Idle Mixture ('Low Speed Needle')
Old 06-10-2009 | 05:58 PM
Jetdesign's Avatar
Jetdesign
My Feedback: (8)
Default RE: Setting Idle Mixture ('Low Speed Needle')
I was just trying to get an educational thread about tuning in the beginners forum.
I understand the bleeder valve on my YS is different than the carb on my OS 2 strokes, but the principle is the same - adjusting the mixture of fuel and air at low engine speed. YS engines, despite the pressurized fuel system, do suck fuel at idle speed like a standard 2 or 4 stroke.
The point I was hoping to make - if it is correct - is that tuning any of these engines so that they maintain a constant idle RPM for a period of time seems to be the most accurate and reliable method I have found.
I agree the transition quality and pinching the lines gets you close, but if you don't have tons of experience where do you go from there? I feel like the steady RPM way takes some guessing out of the game.
I wish I had known this a year ago, which is why I'm posting it in the beginners forum.
