RCU Forums - View Single Post - Low Compression ???
Old 06-10-2009 | 08:42 PM
  #59
captinjohn
Default RE: Low Compression ???
ORIGINAL: tony0707
HI RCPILOTI use FRANK BOWMAN rings to replace my ringsabout two dozen to date- frank is the man when it comes to replacement ringshis instructions are to use 320 grit emory and oil lightly-as i have stated -standard proceedure to replace a ring according to frank -now what is your problem with tthat-no one said anything about honing but youby the way all my replacement rings brought the engines back to new compression-enough said !!
I have read somewhere some types or (brands)of emory is not good too use. I would get a quality USA brand if you do the emory cloth trick. Make sure you do it with the exact way Frank says. Probablywith light oil...with light pressure! Capt,n
