RE: Engine Stuttering in inverted
Sounds like a fuel tank or mixture issue, check the tanks lines,clunk,and make sure everything is properly installed, then state the engine and full throttle it and hold it inverted see if this fixes it... if not then lean or richen the engine as needed</p>
