RCU Forums - View Single Post - Setting Idle Mixture ('Low Speed Needle')
Old 06-11-2009 | 07:49 AM
Lnewqban's Avatar
Lnewqban
Default RE: Setting Idle Mixture ('Low Speed Needle')
ORIGINAL: gaRCfield
For the past year I've been adjusting my idle mixture based on transition from idle as per manufacturers instructions and what I've read on this forum. I recently had to learn how to work an air bleed adjustment on my YS, and the directions for that were to tune the mixture to maintain a steady idle RPM over a period of 15 to 20 seconds, and not based on transition or a fuel line pinch.
gaRCfield:
Could you explain this a little better for me?
Sorry, but I see no difference between what you were doing before and now, other than switching from idle needle to air bleed.
CGRetired:
For some reason, many members are not aware of the engine forums.
May be showing a link within RC Airplanes forums would help?
There are also very interesting forums about full scale airplanes, batteries, radio systems, unusual models and video and photograph here in RCU.
