RE: Using an expanded scale voltmeter
H'mmm no 6 volt. Hadnt thought of that. I'm using 4.8 now but if I moved to 6 volts this meter would not work....
Which brings up another question.
the merits of 4.8 volts vs. 6 volts OR Spectrum says you can plug two identical batteries into the AR7000 RX.
I have two spectrum Nicads 4.8 v 1100mah I could use.. ( in place of the Nimh 1700mah I'm using now ) which would be better?
Sorry, this battery area is my weakest link.....
Steve
