RCU Forums - View Single Post - Using an expanded scale voltmeter
Old 06-11-2009 | 02:56 PM
Popriv
Default RE: Using an expanded scale voltmeter
Yes I thought it strange that they give you the 4.8 Nicad!
I am not using the digital servos now so I guess I'm safe using the 4.8 volt.
My biggest fear is losing control...When the plane doesnt respond right away or if the wind does something to it my heart stops.
Would a 6 Volt pack just be 5 - AA's instead of 4 - AA's?
I did pay extra to get the Spektrum switches hoping I'm getting better quality? They seem heavier duty?
Steve
ORIGINAL: Gray Beard
This meter isn't one of the high dollar meters, you just read your 6volts from the 4.8 side, no big deal. Irun two batteries and one battery, 6 volt and 4.8 volt. Sort of what kind of mood I'm in when I'm building and setting up a plane. With two batteries you want two switches and batteries of the same volt and mah. Ieven run one 6 volt battery with two leads going into two different switches. Most the time it's the switch that fails and not the battery. In this case it's a big sub C pack with very high mah with the battery being double wired.
So much has beer writen about batteries and it comes down to the pilots choice. Horizon has come out and stated you should have a 6 volt system in your plane if you are running there digital servos and 2.4., they only give you the 4.8 though.
