RE: obliterated brand new corsair
and if you have gaps, find some foam about the same density, cut the crushed or missing area to a neat straight size, cut some foam to fill the area.<div>Don't worry about getting the outside shape right, cause you sand that down after the glue has set.</div><div>
</div><div>Foam is easily fixable. Unless you have a mid air with a heli as happened at our field, then no amount of glue could fit all that foam snow back together.</div>
