RCU Forums - View Single Post - Nitroplanes A-10 Warthog help needed
Old 06-11-2009 | 07:43 PM
opjose's Avatar
opjose
Default RE: Nitroplanes A-10 Warthog help needed
LiPo's discharge very rapidly when they are connected to a low resistance sink.
This puts them over their thermal limits causing the polymer material to break down... you normally get a lot of heat out of the packs, and you'll notice a slight "puffyness" to the packs.
If the packs look like they did when you got them, with no new puffyness or squishyness, they should be OK.
The ESC is a pre-wired 10A brushed ESC.
See: [link=http://www.nitroplanes.com/guanlibrushesc.html]Click me for ESC[/link]
The motor is a fairly common Mibushi ( sp? ) type can brushed motor, used in many devices and commonly available.
[link=http://www.nitroplanes.com/guanlimotor.html]Motor click me![/link]
Guan Li is the vendor, but not the manufacturer of the motor.
In your shoes, since I would be looking at purchasing a replacement ESC anyway, I would look for a LiPo compatible brushed 10-20A ESC that I can use.
However this requires doing a bit of rewiring and is not as convenient as one of the drop-in replacements.
Of course you can go nuts in the other direction ( which I often do ) and opt for dual brushless motors with dual brushless ESC's but this would cost more to do than what you paid for the plane.
