RCU Forums - View Single Post - How bad are the diff problems on the savage??
Old 06-12-2009 | 07:16 AM
supertib's Avatar
supertib
Default RE: How bad are the diff problems on the savage??
ORIGINAL: spiftacu1ar
ORIGINAL: SAVAGEBANE
cen diffs.....nemesis or genesis, which ones fit into a savage X?
is it best to get front and rear or is one far more likely to blow out than the other with a powerful engine?
The cen nemesis, genesis, and matrix all use the same diffs. Here is a guide to installing: http://www.rcbasher.com/savcendiffs.html
You cannot replace just the fornt or rear, you have to to both. THis is becasue the cen diffs have a differnt ratio from the stock ones, so your wheels will be going at differnt speeds if you don't replace the front and back at the same time.
Herrsavage:
You realize you can use the cups from ANY vehicle with a 6mm shaft (tranny output) or 8mm shaft (diff input), so quality of the cups is a moot point. You can buy the cups from another vehicle, as they all use the same standard dogbones.
I wonder if you can use Mugen outdrives and cups ?
