ORIGINAL: GrayUK
<div style="margin: 0cm 0cm 10pt">I disagree with this completely.</div><div style="margin: 0cm 0cm 10pt"></div><div style="margin: 0cm 0cm 10pt">Pos 1 and 3 are sort of acceptable but who the hell flys like that?</div><div style="margin: 0cm 0cm 10pt">Pos 2 is the most common position, and to quote Horizon</div><div style="margin: 0cm 0cm 10pt">“ a cone of silence” directly off the end if the TX.</div><div style="margin: 0cm 0cm 10pt">So why recommend a position with that ‘cone’ pointing where you fly?</div><div style="margin: 0cm 0cm 10pt">If you check the JR site they recommend the aerial facing down at 45 deg.</div><div style="margin: 0cm 0cm 10pt"></div><div style="margin: 0cm 0cm 10pt">Paul</div>
Paul do you have a link to the JR recommendation?
Phil.
