RCU Forums - View Single Post - xyz cdi
Thread: xyz cdi
Old 06-12-2009 | 09:53 AM
  #52
tkg
Default RE: xyz cdi
ORIGINAL: combatpilot
If the timing is to far advanced, like 35 + deg BTDC then it may develop a HS speed miss, almost like it is to rich. BUT you can't tune it out using the carb needles.
That would be as not set dead on 28 degrees right????
Ok lets say just for argument sake that it is set spot on 28 degrees just like its supposed to be. At that point wouldnt you look at the carb????
thanks for the info Ralph
The carb is a simple adjustment so go there first. But if it doesn't help the HS miss, the timing COULD be a problem, also weak ignition, bad spark plug, weak battery, bad switch and so on.
