RE: xyz cdi
Ive changed the plug and gaped it at 25. The battery has a full charge Iam missing something and cant figure it out. Let see if i am doing this right. I start with the piston set at top dead center and set the degree wheel to read 0 and rotate the engine ccw to read 28 degrees and lock it down if that is right then i did it right right?
