RCU Forums - View Single Post - HBFP Problems
Old 06-12-2009 | 12:13 PM
Robertwav1
Default RE: HBFP Problems
One of mine had a shake for a while till I figured out it was the flybar and paddles. They have to balanced also. Easiest way is to remove the rotors and tip the flybars back and forth noticing balance. Shouldn't be any binding here either. I use a metal flybar and measure everything but obviously that's not good enough. Check the balance.
