RE: New Hitec Aurora 9-Channel 2.4Ghz Radio System
Hi Mike,
Thanks for your reply.
Iexpected that scan mode would take more time (only makes sense). But it is good to hear that the resync time is short.
Two other questions:
Are the Aurora receivers all considered full range (I have no idea why Spektrum has short range receivers like the 6100)?
Does the Aurora support a model memory match as the Spektrum DX7 does (such that each receiver is bound to a specific model number - eg #7, T-28)? The idea being that your transmitter must be set to the correct model in order to prevent an error in selecting the correct transmitter memory for the aircraft you are planning to fly?
Thanks again,
John
