RE: Engine Shut Down and Break In
David,the only way a engine can continue running with the throttle shut is if a air/fuel mixture is leaking in from somewhere else. if anything, this is more likely to happen in a engine that has logged some hours and developed leaks from failed gaskets and seals, along with loose tolerances insleeve bearing typeengines.
