RCU Forums - View Single Post - Too much thrust angle
Old 06-12-2009 | 11:50 PM
RCKen's Avatar
RCKen
RCU Forum Manager/Admin
My Feedback: (9)
Default RE: Too much thrust angle
No, you DO NOT move the mount. If the nosewheel is set on the centerline of the plane, this is where it's supposed be. If you move the engine or mount to fit your off center cowl you are going to put some very bad thrust angles into the plane, which will cause all kinds of problems flying. Like I said, you need to cut the cowl off and rebuild it properly. Or live with the cowl being off center.
