RCU Forums - View Single Post - Engine Shut Down and Break In
Old 06-13-2009 | 02:52 AM
freeair
Default RE: Engine Shut Down and Break In
so what some people have said is; the engine wont shut down unless the engine is broken in [ run in ] what a load of you know what.
this problem seams to happen with worn out engines where the front bearing leaks air into to crankcase of the carby develops some slop in the barrell / needle valve / or carby to case connection. GMS engines are bad for this .
