RCU Forums - View Single Post - Engine Shut Down and Break In
Old 06-13-2009 | 04:51 AM
pe reivers
Default RE: Engine Shut Down and Break In
I had a Webra speed  .40, that had the shaft with quite a bit of play in the housing for best power. That play was enough to keep the engine running.
I solved it by adding some teflon oil to my after run treatment. Then bye the bye, as the teflon built up on the shaft, the engine would stop reliably.
