RE: CAP or Extra?
Those are the best times to fly, I show up at around 4-5 pm and fly till the sun goes down, it's a little cooler and the suns not beating you down so bad. I got the turtle deck shaped and sanded, I just added a small fillet of hobby lite balsa filler around the base of the vertical stab to blend it in. Other than that I have a smidge to go and I'll be past you by today and finalizing control layout soon. I'll upload the pic's to my laptop (the balsa encrusted thing on the bench) and I'll post the update, there's a little trick in there for protecting vertical stabs while sanding, masking tape is good, but doesnt protect from impacts with the sanding bar. I show you the stupid little thing to do to help avoid fixing stuff that's dinged or nicked because of carelessness.
