RCU Forums - View Single Post - obliterated brand new corsair
Old 06-14-2009 | 03:08 AM
basman
Default RE: obliterated brand new corsair
sgt peanut ......awesome job on the rebuild thats a credit to you.
Two things 1. howis the balsa engine mount fixed to the foam block on the fire wall. Is that block solid, and if so is that a strong connection?As you said youdon't want that coming loose.
2. Test your paint on anoff cut of foam to make sure it doesn't reactwith it. Iam not sure what youcan your lhs may be ableto help.
Great job on the cowl like yourfixing points ........................ keep it up cheers
