RCU Forums - View Single Post - Reciever lockout
Old 06-15-2009 | 04:13 AM
  #78
i3dm
My Feedback: (51)
Default RE: Reciever lockout
<div><font face="Arial" size="2">I spoke to the owner of Powerbox Systems and told him about the problem. i also told him my friend uses his switch in his Jas-39 Gripen jet with five 5955TG and Relions and has no problems. he says that since this is a linear regulator, it will benefit from the higher input voltage thats much higher then the low voltage setting (5.9V) of his switch.</font></div><div></div><div><font face="Arial" size="2">So, now i have3 options:</font></div><div><font face="Arial" size="2">1. stick with a single UN regulated A123 pack directly into the Rx through a switch (badger / wolverine) ?</font></div><div><font face="Arial" size="2">2. a single UN regulated A123 pack, with a Sahara reg + switchinto the Rx.</font></div><div><font face="Arial" size="2">3. replace the Rx pack for 2 Relion 2600 (with the sensor switch) which is a setup well proved to be efficient in my friend's jets.</font></div><div></div><div><font face="Arial" size="2">To me, despite options 1 and 2 should definitely work well, option 3 is the most proven and testedone.
What would you recommend doing ???</font></div>
