ORIGINAL: MinnFlyer
A roll really won't tell you if a plane is nose heavy.
If you pull the plane up to about 45 degrees, roll over inverted, and continue on that line, the plane should stay at the same angle or just faintly fall off the 45 degree angle. If it climbs more, the plane is tail heavy. If the plane starts to sink, it's nose heavy.
