RCU Forums - View Single Post - Comp ARF BAE Hawk build thread
Old 06-15-2009 | 12:49 PM
  #121
digitech
My Feedback: (10)
Default RE: Comp ARF BAE Hawk build thread
ORIGINAL: geh3
See attached Pics..
pic 1 = down elevator throw
pic2 = up elevator throw
pic3 = neutral set for first flight.. will probably change based on your CG
pic4 = CG,mine is at 7.9" from the front flat part of the wing
Ihave 60% Expo in my elevator
flys great...I'm not sure you can throw this plane around likeyou can with the FLASHbut I only have 3 flights on it so far. The first flight was VERYnose heavy and it landed like a rocket. The second flight was much better with CG@ 7.5". The third flight was at 7.9" but Ihad to land early due to a thunderstorm very near. Good luck with your new one, they do look very nice in the air...
thanks for the data given
this once proofs again that the trows i had was far to big...
my info was 30mm ABOVE that elevator cover , no wonder it was touchy...
what didyou do on ailerons?
