RCU Forums - View Single Post - This is troubling me..
Old 06-15-2009 | 02:26 PM
Bob_B's Avatar
Bob_B
Default RE: This is troubling me..
If you are referring to the grouped in the AFR menu I believe that has to do condition selects and allowing your trims to be independent in each
condition select.
The AFR adjust the travel of both grouped channels simultaneously, Use end points to "Match" the two channels.
