RCU Forums - View Single Post - CG question?
Thread: CG question?
Old 06-15-2009 | 03:38 PM
Popriv
Default RE: CG question?
Thanks Mike but I have to have someone else look at it at the field. Other than what I described everything looks pretty good.
Not to worried about it, Seems to fly good...for me anyway.
About using the vanessa to check CG.
If the stabalizer is supposed to be 0 degrees incidence,does that mean it should be level when the planes balanced? or is incidence only relative to the wing?
Ican eyeball nose up or nose down but if I'm using this device to be more accurate I have to know what is level?
Steve
ORIGINAL: MinnFlyer
Oddly enough, that will have little affect on the situation. Don't look at the ailerons, look at the TE and compare it with the spar.
If it is warped, it will look something like this
