RE: Flex Cable + Nitro!
First off a 32 inch hull needs more than a .21 motor..second I dont beleive a word that guy says I have watched his adds for a long time and his specs leave alot to be desired plus his rating isnt that good...third that is a car engine they have slapped a water cooled head on look at the crank in the pic!! its an sg type crank for trucks and truggies no thread at the end of it to attach any kind of collet to attach youre flex shaft to. you would have to remove the crank and have it threaded on the end and hope there is enough material there ot get threads on it that would match up to anything...bottom line leave it be you would be way disapointed with it when you got it..my 2 cents worth
