ABS SURFACE PREPERATION
iwould like to make a fiberglass copy of a plastic cowl.The plan is to make a plaster mold then lay it up with glass.The surface and seems on the plastic cowl are rough and will require filling,i was wondering what type of material i can use on plastic that i can sand to a smooth finish in order to use it as a plug...
