RCU Forums - View Single Post - Homemade Strip, Square and Triangle Stock
Old 06-16-2009 | 01:48 AM
The Ghost's Avatar
The Ghost
Default RE: Homemade Strip, Square and Triangle Stock
You can also use it for cutting the end of sheets to 45deg for joining. The perspex sheet that I use is only 1/4" thick. Use wingnuts on the two bolts for easy adj.
Charles, I also use lazer line tool for getteing the center line on long lengths. Two 36" length sheets joined shown.
Cheers
ID:	1219181   Click image for larger version
ID:	1219182   Click image for larger version
