Moki 2.1 or Supertigre 3250 in 85" BIG BINGO?
You can save a lot of money on the ST 3250 if you buy one used. They go for about $125-$150 on RCU and the swap meets. Then get a perry pump and carb for about $65 for both and you will have a great running engine. If you buy it new then you still will need the carb/pump to get it to run well, then you should just get the Moki. I own a ST 3000, Moki 180, and OS 160FX and all are comperable in power. The ST is a lower rpm torque monster and likes a little bigger prop than the Moki. I found a never seen fuel 3250 for $150 so you can too.
