RE: wheels turned to the right
First, I would make sure that on pebble is lodge in the steering linkage creating a bind. Second, remove the servo arm and make sure the servo is working. Make sure you have your steering trim centered or at zero and your wheels are straight before you reconnect the servo arm.
