RE: electric brushless motor
<span style="font-size: larger;"><span style="font-family: Comic Sans MS;">I would say get the DualSky 60A (USD70) if you are ordering from 2Dogs. If not you can save some money using the Turnigy 60A from HobbyCity. They work fine as I used both and have no issues at all. The Turnigy is cheap (USD40) but not in stock at the moment.
Both have built in UBEC so you can run more than 3S on them and power the RXat the same time. The DualSky has a switch built in, so it gives you 'some' safety ... please note it is not proven that the switch in the OFFposition will mean the ESCWILLNOTarm when the battery is plugged in. It may until proven to be impossible.
I am running the DualSky on a 5S Sebart Angel and the Turnigy on a 5S GPBig Stick 40. Both are running fine.</span></span>
