RCU Forums - View Single Post - OS55AX
Thread: OS55AX
Old 06-17-2009 | 09:21 AM
Bax
Default RE: OS55AX
The "thrust washer" goes between the drive washer and the front bearing.  It only provides separation, it does not prevent any movement.  If your crankshaft has radial movement in the bearings, then you have either or both of the front and rear bearings going bad.  At any rate, if the crank moves radially in the bearings, then you need new bearings.
