RE: Kit Bashing a TF Cessna 182Q to a 1956 Cessna 182
Everything dried over night so I did the preliminany sanding. Needs alittle more final sanding, the Fastback and Side Windows came out good. I'll finish up sanding the Fuselageand Tail Feathers and then completethe Font End (ie. Servo's, Fuel Tank and Fuselage Forward Deck) and then onto Building the Wing. I know I'm building out of sequence with the instructions,butthis is the way I like to build if I can.
rcflyer35
