<div>this is all very interesting !! and 9570seams to bepretty good considering we are running our AX 46right at12,000 on 15%,,</div><div></div><div>borna,, if you do feel you need more power you could buy a gallonof say 30% heli fuel and add some toeach gallon ofgasoline, mixing this way a gallon of heli fuel should last you a few years..</div><div></div><div>Gass/Glow mix how-to,,</div><div>
http://www.rcuniverse.com/forum/m_8009384/tm.htm</div><div></div><div>with the ignition I myself would be concerned about weight unless the plane was tail heavy to beginwith,, Iwould like to do the crank bearing mod and burn the Gasoline/Glow Mix with a 4st Plug and not use the ignition, I got to get my 4-Star 60 back together LOL</div><div></div><div>Jim</div>
