RCU Forums - View Single Post - Fliton Extra 330s 120C Build Thread
Old 06-17-2009 | 07:39 PM
Jimeni's Avatar
Jimeni
Default Fliton Extra 330s 120C Build Thread
Just got my Fliton extra 330, starting a support, and build thread. The plane is very well built, and almost too pretty to fly, almost All of the hardware needed to build is provided in the ARF kit. I plan to use it all except the CA hinges. This plane is way too big for CA hinges, DONOT use them. I'm using Dubro flat nylon hinges. I personally dont care for the pull pull rigging couplers, so I am changing to Dubro 4-40's. The couplers supplied are fine though. Carbon fiber wing tube, and painted carbon fiber gear are provided. The horizontal stabilizer is a fixed style. You can get the plane here http://www.advantagehobby.com/produc...175&page=1Advantage is the USA distributor for Fliton.
My set up is going to be:
MLD 28 cc gas engine. It is the engine shown in the manual and you can get it here.
http://www.cermark.com/products/MLD%...AS-ENGINE.html
Smartfly ignition regulator http://www.cermark.com/products/SMAR...Regulator.html
Smartfly optical ignition kill. http://www.cermark.com/products/SMAR...on-Cutoff.html
Vess 18x6 prop
Hitec HS 5625MG servo's all around, HS81 on throttle. http://www.hitecrcd.com/servos/list
7.4 volt 2200 mah lipo for RX with Duralite 6 volt regulator, and 7.4 volt 1300 mah lipo for ignition.
Tru turn 3" spinner.
Here are some pictures I have so far.
ID:	1220096   Click image for larger version
ID:	1220097   Click image for larger version
ID:	1220098   Click image for larger version
ID:	1220099   Click image for larger version
