RCU Forums - View Single Post - Picorare Build Thread
Old 06-17-2009 | 11:57 PM
doxilia's Avatar
doxilia
Default RE: Picorare Build Thread
Here's a quick itemization of the gear I plan to use:
<ul>[*]Servo's: Futaba S3114's (4)[*]ESC: Castle TB36A / 3A BEC[*]Battery: Thunder Power 2100 3s Pro Lite[*]Motor: Dualsky XM2834CA - 6 (1460 KV)[/list]The rudder and elevator servos will be mounted inline as shown in the sketch with the Rx in front of them. A light P-P linkage will be used on the rudder while a forked glass arrow shaft pushrod will be used for the elevators.
The two aileron servos will be mounted in the wing center and will each opearate a torque rod. Using two servo's will allow independed control of the flaperons.
The battery and ESC will be mounted to a plate (one on each side) located on the thrust line while the radio tray will reside deeper in the fuse at the tuck line.
More on that coming soon.
David.
ID:	1220247   Click image for larger version
ID:	1220248   Click image for larger version
ID:	1220249   Click image for larger version
ID:	1220250   Click image for larger version
