RE: DL50 Ignition timing setting guide.
I was reading the timing procedures from both of the links provided. The Rcexl site states to turn the engine clockwise opposit the running direction to set the timing. How much difference is there between turning the engine cw or ccw when timing the engine? If this is important, why doesn't the CH site tell you which way to rotate the engine when checking timing?
Greg
