RCU Forums - View Single Post - xyz cdi
Thread: xyz cdi
Old 06-18-2009 | 10:00 PM
  #83
captinjohn
Default RE: xyz cdi
Combatpilot...lets have a good time on here. I am not putting you down, but just trying to explain a easy way to get a engine to run good. Some people do not want to use any special measurements at all. The 28 degrees is just a close setting. Exact numbers is not needed...but ok if you like that way. Some guys have even removed the key on a flywheel mag and advanced the timing a tad without the key and just a little locktite. Hey there is no cut in stone way to set up any engine. Before auto advance there was linkage tied in with the throttle on carb to get advance at different RPM. It worked good. The more ways mentioned on here gives each guy a choise...whatever is the most easy way for him. I refuse to get mad and go off....it is not good and not my style. Take Care and be yourself &amp; let everyone else be there-self! Capt,n</p>
