RCU Forums - View Single Post - KING TIGER The Ultimate Matorro Modified
Old 06-19-2009 | 03:19 AM
blitzkrieg65's Avatar
blitzkrieg65
Default RE: KING TIGER The Ultimate Matorro Modified
ORIGINAL: philipat
Looks great.
How about some pictures of your magnets, where you placed them, etc? And some of the charging port? I noticed that the battery box is still there. Will you be cutting it out and waterproofing the lower hull?
Thanks guys,
Philipat
No water proofing on this tank,, I think if your going to put EL Mod in it you might not want to risk that,,, but now the challenge is on for a future build! Here are some pictures of some of the areas you requested including the magnets I have glued them onto the screw stand offs and the screw hole area they are high power maganets! I removed the bubble on the bottom hull also!
Phil
ID:	1220908   Click image for larger version
ID:	1220909   Click image for larger version
ID:	1220910   Click image for larger version
ID:	1220911   Click image for larger version
ID:	1220912   Click image for larger version
