RE: Heng Long noob is disappointed.
Check the batteries in the transmitter. Sometimes the light comes on but unless the batteries are in right it won't transmit.
Push each pair of batteries away from the spring end. If you're using rechargable batteries you may need to remove the little sliding tabs that seperate each pair of batteries.</p>
