RCU Forums - View Single Post - xyz cdi
Thread: xyz cdi
Old 06-19-2009 | 10:54 AM
  #93
combatpilot's Avatar
combatpilot
Default RE: xyz cdi
OMG this is just unreal. I just saw the video. I will concede that you do seem to have a pretty good feel on finding TDC with the slop method. Still this is not garunteed accurate. Funny how you back it up with the piston stop method which is the only true way to know for sure. Granted i will give it to you that you do seem to be pretty accurate withyour method but still it is not garunteed.I would not have belived it had i not seen it.
michal wood replies.
what are all the parts used to make a piston stop? the way you did that wasso super easy thanks michael
Which is what i been working so hard to try to get you all to understand.
Can not one of you bite your pride and concede to me that the piston stop method is absolutly accurate easy to do and not expensive and my time and effort and frustration was worth something????
I just dont understand how you can work so hard to discredit my info then steal my ideatomake avideo using and describing the very methods i use and describe and now suddenly their right?
