RCU Forums - View Single Post - KING TIGER The Ultimate Matorro Modified
Old 06-20-2009 | 03:36 PM
blitzkrieg65's Avatar
blitzkrieg65
Default RE: KING TIGER The Ultimate Matorro Modified
ORIGINAL: RSEA
I was interested in that ELMOD system for my Tamiya King Tiger but read a lot of comments about problems with the new Blaster III board and poor battery life. Someone stated that a 4000maH battery pack would only give you about 20 minutes run time, which I find to be unacceptable for my proposed use (IR Battles). Another was that they wished the Blaster II was still available as it had less problems. Poor customer support from the producer ofELMOD inGermany was another complaint.Poor instructions for installation (unless youcan read German well). Speed 400 motors damaging the EL MOD control board. Having to ship malfunctioning boards back and forth to Germany and still having issues afterwards with getting the units working correctly, etc.
It didn't sound promising at all.. Anycomments from you about all this, Blitzkrieg65?
Hello RSEA
<span style="font-size: 12pt; color: #444444"></span><span style="font-size: 10pt">I am the North American Distributor of EL MOD Products my manuals are in English, my customers get personalize service if they are having any problems! As you can see there are not those complaints on this forum! I have read guys having a problem in England, and Iwas concerned about the </span><span style="font-size: 12pt">new</span><span style="font-size: 10pt"> system, but I have sold over a dozen units now and </span><span style="font-size: 12pt">none</span><span style="font-size: 10pt"> of the problems like they are describing! If you read the latest manuals on EL MOD you will see it is a much easier setup then the old system and if you have </span><span style="font-size: 12pt">a</span><span style="font-size: 10pt"> questions I will be glad to answer them</span><span style="font-size: 12pt">! Now as far as power drain, an</span><span style="font-size: 10pt">d battery life it is the same as the old system,, yes EL MOD is a power hog! But I too do IR battles and if you could have made it to the SCAT battle you would have seen about 4 EL MOD tanks there battling without a problem! I do use a 4600 mah, Duratrax battery in my EL MOD and I get about 2 hours out of it!
Also the new system has a computer interface called "the Configurator" that makes it many of the </span><span style="font-size: 12pt">functions </span><span style="font-size: 12pt">adjustable</span><span style="font-size: 10pt"> including multiple recoils systems and the timing you want out of those systems! Here check out the manuals, the new system manuals are on the top!
http://www.rctankwars.com/Manuals.asp
Philipat,,
No </span><span style="font-size: 12pt">interference</span><span style="font-size: 10pt"> problems and I will show on the video how it removes and how it looks when going over </span><span style="font-size: 12pt">twisting</span><span style="font-size: 10pt"> terrain!
</span>
Phil
RCTankWars.com
