RCU Forums - View Single Post - E-flite BAe Hawk 15 DF ARF
Old 06-21-2009 | 06:43 AM
Greg Covey's Avatar
Greg Covey
Default E-flite BAe Hawk 15 DF ARF
E-flite’s [link=http://www.horizonhobby.com/Products/Default.aspx?ProdID=EFL8025]BAe Hawk 15 DF ARF[/link] is a sport scale version of the trainer and light combat aircraft for use by the British Royal Air Force. This R/C model is constructed of fiberglass and balsa, the fuselage is beautifully prefinished with scale details. The British Aerospace (BAe) Hawk boasts the rare and very visible Central Flying School airshow trim scheme from 1987 in red, white and blue.
This exciting R/C model was designed around E-flite’s [link=http://www.horizonhobby.com/Products/Default.aspx?ProdID=EFLDF15]Delta V 15[/link] (69mm) fan unit and matched [link=http://www.horizonhobby.com/Products/Default.aspx?ProdID=EFLM3015DF]BL 15 DF[/link] brushless motor. Pilots can use a 3-cell LiPo battery pack or utilize a 4-cell LiPo battery pack for increased vertical performance. The built-in fan mounts make installing the fan easy—just drop in the fan unit and tighten four screws. The removable front hatch also allows easy access to the radio equipment and battery. The entire trim scheme is pre-painted, pre-trimmed, the wings are covered in UltraCote and all the decals have already been applied. Created for the advanced sport scale pilot, the BAe Hawk 15 DF ARF easily lives up to its reputation of being a stable flying jet.
Key Features:[ul][*] Molded fiberglass fuselage and built-up balsa wing construction[*] Pre-finished scale trim scheme of Central Flying School RAF BAe Hawk[*] Designed to fit the E-flite® Delta-V 15 EDF unit and BL15 DF Brushless Motor[*] Built-in fan mounts[*] Pre-assembled quick access cockpit hatch[*] Removable landing gear[*] Concealed elevator linkages[*] Optional pilot figures sold separately
[/ul]Specifications:[ul][*] Wingspan:33.3 in (845mm)[*] Overall Length:35.4 in (900mm)[*] Wing Area:206 sq in (13.2 sq dm)[*] Flying Weight:43–46 oz (1219–1304 g)[*] Motor Size:15 DF brushless motor[*] Radio:4+ channels[*] Servos:Sub Micro (3 required, 4 with nose gear steering)[*] Speed Control :60-amp brushless[*] Recommended Battery:3S 11.1V 3000-3300mAh Li-Po[*] Landing Gear:Optional use, included
[/ul]
ID:	1221861   Click image for larger version
ID:	1221862   Click image for larger version
ID:	1221863   Click image for larger version
ID:	1221864   Click image for larger version
ID:	1221865   Click image for larger version
